GaryP
Cosmos: Solid State Drive adaptors
GaryP    1
As above. I have a £150+ case and can't use a SSD satisfactorily.
A simple solution like this ..
.. available at standard post rate would be perfect.
Thanks
  • Upvote 1
clorenz    2
The case may not come with SSD brackets, but I have found that standard SSD brackets from various vendors work quite well in these cases. However not many PC case manufacturers offer SSD brackets with their cases, maybe this is one where CM should set up and take the bull by the horns so to speak :)
  • Upvote 1
reinier    0
this forum s F up .
when your writing and hit the backspace key t erases everything #@$@@#$
:angry:
tso 3rd time SSD HOT SWAP DRIVE BAYES 2.5INCH
cos you can't seem to buy 3.5 inch drives switch the hot swappies to 2.5"
world    84
this forum s F up .
:angry:
I don't have any problems with backspace erasing everything icon_scratch.gif
