jjustinia11
Can anyone recommend a blue LED fan for the HAF x front
jjustinia11    0
Can anyone recommend a blue LED fan for the HAF x front? I dont own this case yet, but ultimelty would like to have a blue LED on the front and not red. Is this possible, is it a swap of the existing red fan. Dont have the case yet but trying to plan for a early January build.
jannie    0
Hi There,yes I just converted my hafx to blue, you can buy a spectre 230mm led fan and it has a switch for off/onn..Cheers Dave
jannie    0
Not very sure about the 200mm,I don't have a 200mm to try it for you It does have three different fixing holes, so I imagine coolmaster have catered for this.It seems to be easy to buy a blue 230mm, but not so many companies have the off/on switch facility, which is incorprated in the haf x...Can I ask which mobo you are fitting..I have two of these cases, one blue and one red, both with gigabyte mobo's..They really are brilliant cases.
