zephyrus17
212 Plus: Small buzzing sound
zephyrus17    0
I can't really pin point if it's the 212 Plus or the exhaust fan for the CM 690 Advanced, but there's this slight medium-high pitched buzzing sound (not really sure how to explain it) that's coming from either of those two. I checked and I'm pretty sure nothing is in contact with the fans, so it's probably just from the vibration. Could it be that fan is slightly wobbly?
IceDati    0
There are few possibilities .. maybe the fans are not installed well , maybe the cooler itself isn'tt installed well or maybe its the sound coming from the PSU or the HDD you can't always tell .. :roll:
Edit : if its that annoying just take the PC a part and rebuild it all over again .. and this time fix everything up very well ..
Create an account
Register a new account
Sign in
Sign In Now
