hirschma
Get rid of Stacker Control Panel?
xstax    0
I shoulda asked before but what card did you end up using for your raid 5? I was running a 4 disk Raid 5 but the card resently :) the bed on me. I'm planning to get a new case and I'm considering doing another raid 5.
merovingian    0
Supermicro CSE-M35T-1B. About $115 at newegg, pretty decent quality, too.
Uhh, how exactly are you cooling those drives? Also, CM does rackmount storage cases?
hirschma    0
Using a 3ware 9500 series. Very solid under Linux, if not the fastest in the world. The newer 9550 series offers a drop-in upgrade, and i might look into it.
hirschma    0
Drives need cooling? ;) The Supermicro has a 90mm fan to do the trick, and I'm using Seagates which run very cool overall. No issues.
Is that a question? Statement? If CM does rackmount stuff, I can't find it. Are you referring to the drive cages that CM sells? If so, they really aren't appropriate to what I'm doing.
jh
