Rio3344
Change front fan in an older Praetorian case
Rio3344    0
I need to change the front fan in my Praetorian case. I can't seem to see a good way to get to it. Any help would be appreciated. Thanks
do you happen to know your case serial number? That is located at the back of the case where the keyboard ports would be.
The reason why i need it is so i can identify it
Kevin Voong    0
Below you will see the image with 2 red squares. You need a Philips screwdriver to remove 2 screws on each side of the case. Once you get the mess off you can access the fans.
Sam    0
Sorry to bump such an old topic but I am having exactly the same problem as the OP. Unfortunately Kevin's image is no longer there.
Can anyone help with how to remove the front fan? I've been puzzling over this for more than an hour, no luck as yet.
Mohd Noh    28
Hi
suggest you by contacting customer service, they'll help you
Create an account
Register a new account
Sign in
Sign In Now
