Echo
AquaGate Installation Advice Needed.
ninuhadida    0
if you want to see better temps (they good right now 8) ) you could use some as5 (artic silver 5) instead of the supplied paste. i got a drop from 44 to 26c 8)
Echo    0
Thanks, I'm "hooked" on CoolerMaster :D and is Artic Silver 5 really that good?
Currently running on fan speed 1, water temp is 35.2 C and CPU temp is 44.5 C (monitoring via motherboard, thermal probe on AquaGate is monitoring case temp which is 30 C and SYS temp is currently 36 C, next step is the CrossFlow fan and then another 4in3 module.
ninuhadida    0
it will sure go down by 15c, right now my temps are cpu 28c without fan on radiator, and with the fan on 12v it goes down to 18c (+3c of ambient temp) 8)
Echo    0
AquaGate water block, in place and running
AquaGate pump, resevoir and controll unit. (CPU probe is currently measuring ambient temps in the case, wish the CPU was that cool :D)
All that's left is some cable management ;)
AquaGate cooled INTEL 3.0E (Prescott) 50 C under SiSoft CPU burn in test!
