crazyg0od33
HAF 932 front panel connectors
crazyg0od33    0
I saw in a youtube video that a builder got the front panel wires behind the motherboard tray area somehow. I don't know if the headers start back there or not, but if they don't, how would I get the cables back there with no modding of the case?
Also where would you recommend stowing away the front connectors I don't need?
Kevin Voong    0
I normally run the cables on the right side of the case. There are zip ties that are provided that you can use to hold the cables to the chassis. Since once the case is up and running you hardly need to remove the right side panel.
