boredgunner
ATCS 840 Fan Question
boredgunner    0
Is it possible to use a Storm Force 200mm fan in place of the 230mm fans on the ATCS 840? Someone told me the Megaflow 200mm fans are advertised to fit the ATCS 840, and they are. Would I have to drill some holes for the fan to fit?
Thanks in advance.
boredgunner    0
the megaflow 200 will fit perfectly in the ATCS 840 cases as well as any cases in the past that uses the 230 x 200 x 30mm fan.
Thanks, so I suppose the Storm Force 200 will fit too?
boredgunner    0
The CM force fans will work, however the LED light wire are on a separate plug to be used on the Sniper cases.
Thanks for the confirmation. I can live without LEDs since the stock 230mm fans don't have any. 142 CFM here I come!
