Otniel Ruelas
General: How to monitor/check cpu temperature
Core Temp is a compact, no fuss, small footprint program to monitor CPU temperature.
Now Windows Vista and Windows 7 ready! (x86 and x64)
This neat little program will help you check your cpu temp, most reviewers use this as part of their program package to measure temps. Specifically measures cores in a quad core or dual core processor.
If the temp reading is higher then what care has to be taken?
lizhuberX3,
Depends on your setup and if you're overclocking.
So please tell us your system specs, CPU cooler used, computer case and if you're overclocking.
nickt1862
