Barso
Rear fan on cosmos S case not working?
Barso    0
I have the coolermaster cosmos s case but I have just noticed that the rear fan is not running.
It appears to be plugged into the motherboard which is an ASUS P6T deluxe V2.
Should I be worried and is there a way to check that it works?
Thanks to all help and replies.
Zenphic    0
I think the fans come with a 3 pin to molex adapter. Try using that and plugging the fan to the power supply to see if it works.
knud    129
If it turns out not working, please contact customer support for a replacement :)
