hawaiian_geek
90 CFM Blue LED Silent Fan 120mm (R4-L2R-20CK-GP)
Mysteoa    0
Hi,I saw that you ware discussing the same fan that I have. My fan recently started to be little noisy . So I tried to put some oil but I couldn't find from where. Does someone know how to do it or to remove the blade? And another question. Is it possible to change the led because it's not working?
dusters16    0
Are all the these R4 fans supposed to be the same in specifications?
Smoked (69 cfm)
http://coolermaster-usa.com/product.php ... ct_id=2916
Blue (69 cfm)
http://coolermaster-usa.com/product.php ... ct_id=2915
Green (90 cfm)
http://coolermaster-usa.com/product.php ... ct_id=2914
Red (90 cfm)
http://coolermaster-usa.com/product.php ... ct_id=2913
If they are, can they be updated to reflect the same specifications?
I would like to get the Blue LED fan, but am unsure about the CFMs
Also, does CM make any 120mm fans that have a 4pin PWM (cpu fan)? I would like to replace the CM V8's fan with another PWM fan that has Blue LEDs.
so far I have found this one
http://www.performance-pcs.com/catalog/ ... s_id=27555
And here's my case, an Antec 1200 with 7x 1200mm Antec Tricool Blue LED fans, a 200mm top exhaust and the V8's 120mm.
