hawaiian_geek
90 CFM Blue LED Silent Fan 120mm (R4-L2R-20CK-GP)
I see this is a new 120mm fan that also comes in Red and Green LED. Does it really push 90 cfm? If so then I'd consider making a purchase of them for my CM 590 & 690 case as well as using them for builds that I do for customers. I'd appreciate any CM rep who could reply to my question. Thanks in advance! :)
Icejon    0
Yes according to the spec it pushes 69.99-90cfm. We use a narrow hub with sickle shaped special blades. The 90 CFM will be achieved in the most ideal conditions using 2000rpm +/-10%. Try one for yourself, it really blows harder than all the LED fans on the market. Compared to some non LED but high RPM fans from one of our Japanese competitors it is neck and neck, though our solutions has a slightly different aural quality because of our sleeve design.
nielyee    0
I have one of these busters and i really must say that they push more air than any standard non-led fans out there.
Most of the time, i can achieve about 1920 RPM and have a CFM of 82.6.
It's really good and you'll be surprised with the results.
bobfig    0
so are you saying that both of these fans are different?
http://cmstore.coolermaster-usa.com/product_info.php?products_id=116
Specifications:
Fan Dimension (W / H / D) 120 x 120 x 25 mm
Fan Speed 2000 R.P.M.
Fan Airflow 69.69 CFM
Bearing Type Long life sleeve
Fan Life Expectancy 50,000 hours
Fan Noise Level (dB-A) 19 dBA
Connector 3-pin
Voltage 12 V
and
http://csxstore.coolermaster-usa.com/product_info.php?cPath=18_32_39&products_id=262&osCsid=762c5a5a8789c27329916dae72263016
Dimension 120 x 120 x 25 mm
Voltage 12VDC
Current (Ampere) 0.35A
Input (Watt) 4.2W? 10%
Speed (R.P.M.) 2000 R.P.M.
Air Flow (CFM) 90 CFM
Air pressure (mmH2O) 2.94 mmH2O
Fan Noise Level (dB-A) 19 dB-A
Weight 116 g
Available Color Blue LED
Bearing Type Long Life Sleeve
if so then how? because they just seem like the same fan with a new moter. ether way they spin at the same rpm's with the same fan blades. and what do they mean bye "ideal" situations.
Ideal would be, nothing blocking it's airflow(intake & outtake)..least to me anyway. And I would imagine a new motOr would make it different if that's the case. And for $3 more, are you that worried about the blades ? lol...I'm just glad they came out so i can switch out the Red ones in my V10
bobfig    0
im not worried about the blades. its just not physically possible to push the same amount CFM's with the same blades spinning the same speed even with different moter.
Icejon    0
Actually the top fan is 800-1800RPM the spec isn't exactly right. This sort of fan is used on a CPU cooler like a Hyper Z600 or a Vigor Monsoon III.
The bottom fan R4-L2R-20AC-GP is similar but better. It is a R4 series fan like the top fan meaning they share the same blade design in general, but with significant changes. First it is 2000RPM and we eliminated the speed limiter. We also increased the input voltage. Both of these contribute to higher specs with increased output. They are both great fans, hope that helps.
VALKYRIE    11
The fan that was with my Hper 212 ( I bought two years ago ) have the specifications showed below
Voltage 12VDC
Current (Ampere) 0.37A
Bearing Type Long life sleeve bearing
Fan Air Pressure 2.94 mm-H2O
Connector 3-pin
The specifications of the brand new R4 fan are
Voltage 12VDC
Weight 116 g
How can be possible to have differents airflow in two fans that share exact the same blades exact the same speed RPM exact the same bearings exact the same air pressure ? physically impossible
Overall I like very much this fan because of the extreme silent sleeve bearing and the beautiful shape of the blades ( very nice look ) , the problem is this fan is not available Full Black Matt colour without LED ,and to be honest I HATE fans with LED
boredgunner    0
Voltage 12VDC
Connector 3-pin
Voltage 12VDC
Weight 116 g
Icejon just said those specs are wrong. The specs are really 1800 RPM/69.69 CFM/19 DBA. The R4 series 120mm fans mentioned in the OP are 2000 RPM/90 CFM/23 DBA. And yes those fans are awesome (the 90 CFM ones). I have five of them, soon to be 8.
