wr_uk
Running a PC on US & UK power supply with CM Real Power Pro?
wr_uk    0
Hi
I purchased a COOLER MASTER Real Power Pro RS-750-ACAA-A1 750W Power Supply for the PC that I build just over a year ago in the US.
I will be moving to the UK later this year. I want to ship the PC I built I'm wondering if the power supply will be an issue.
I trying to find out If I can just buy a British standard 3 pin plug/cord, plug it straight in and everything run as normal. The last thing I want to do to fry anything.
I think the power supply in the UK runs at 240V and here in the US its runs at 110V.
Can anybody confirm if I would be able to run my PC in the UK by just changing the power cords (at not frying anything inside the PC)?
Thanks
Wayne
EsaT    0
It has active PFC so it works "globally".
(and at ~2% higher efficiency with higher line voltage)
wr_uk    0
the psu should be able to switch modes from 115 to 220
Do I physically have to do anything then with the power supply?
Or its it just a case of buying the power cord and thats it?
