notoriousbigs
Cooler Master V8 - Product Suggestion
Hello,
If you were given a chance to change anything you'd want to the infamous Cooler Master V8, what would you change?
Feel free to post your suggestion in text or image...
Looking forward to see some great ideas.
RaptorFury    0
change the spacing between the fins (to accomidate more airflow). drop the deck hieght by 1/2 " ( from the bottom of the fins to top of cpu base). add 2mm of thickness to the main cpu coolers base (from, the heat pipes to the cpu coolers base's face in that area). and use slightly larger cooling heat pipes
Nereus    0
Nothing; If it ain't broke, don't fix it.
The suggestion above about lowering deck height... with some mobos that may create RAM clearance issues.
VALKYRIE    11
I agree , increase a bit the distance between the fins to allow easy airflow
Appreciated guy, keep them coming. The reason i'm asking is we're going to have something that will kick some major *sses in the market.
VALKYRIE    11
A v8 with a Tec actually mounted to the bottom by the heatsink base?
Can you tell please what is a Tec ?
