EVGAMartin
i7 cooler that fits Cooler Master Cosmos S
EVGAMartin    0
Hi, I really wanted to get a V8 to cool the i7 920 I'm getting, but from what I've seen, it won't fit. Can anyone recommend another good LGA1366-compatible cooler that will actually fit the Cosmos S? If not, will removing the side panel fan affect the internal temps at all?
Thanks is advance,
Martin
boredgunner    0
The side panel fan is large and really helps cool components down. The only Socket 1366 air coolers that I know fit in the Cosmos S are relatively cheap, but I'm not sure about this one.
http://www.newegg.com/Product/Product.a ... man%209900
You may have to go to water cooling if you want to go to 4 ghz and beyond. Water cooling in the Cosmos is no issue though.
EVGAMartin    0
Thanks for the help boredgunner, but I ended up ordering the parts earlier this afternoon. I read something about using a dremel to trim away at the offending part of the fan -- anyone know if this will work with the V8?
Martin
BrettWms    0
The 9900 doesn't fit.. It's too big. Atleast that's what my friend tells me.
The 9700 with the 1366 bracket fits, albeit just barely.
