cmyers
CM eXtreme RP-500 Noise issues?
cmyers    0
Has anyone else had issues with this PSU being overly-loud? I'm not sure if its been like this since I originally got it or its just been a recent issue...(My case fans are pretty loud, so I didn't noticed it until I went to replace my case fans with some UltraSilent Xigmatek's....) Would I be voiding my warranty by replacing the PSU fan? =O
cmyers    0
If you open the casing alone the power supply, you will void your warranty.
Dang...Well, is this kind of noise normal? Is there anything I can do about it that won't void my warranty?
