anand_n
CM 690 & 80mm fan (MOBO)
anand_n    0
I purchased a 80 * 15 mm fan from an online shop and I received the fan without any screws. Is there any screws required for mounting it into the backside of the motherboard tray.
Anand
BrettWms    0
Anand
You don't need anything. The needed stuff is all on the back of the 'tray' for you. Basically, you take off two screws, remove a bracket. Slip the fan into the one end, then put the bracket on the opposite end, then screw the bracket back on..
Remember. CM designed this to exhaust air.....not intake. Whether that's what you decide to do.. heh.. To each his own. :D
