palmero 0 Posted October 30, 2004 I just got the aquagate and when turning on prior to installing in the tower I had tested for leaks. Well all the unit does is beep and the lcd display is blinking untill it shuts down the computer auto. I took off the thermal sensor and the display still blinks and beeps but of coarse does not shut off the system. I dont know if there is a problem with the pci card or if I just did not hook it up correctley, can anybody help? Quote Share this post Link to post Share on other sites
youhouyun 0 Posted November 1, 2004 same problem here Quote Share this post Link to post Share on other sites
[em]HEAT 0 Posted November 1, 2004 It's the thermal sensor. I had the problem to. Just get a new thermal sensor and all should be fine. Quote Share this post Link to post Share on other sites
notoriousbigs 0 Posted November 1, 2004 If you're in the US/Canada/ or Mexico, email customersupport@coolermaster.com and Benson will send you some. Quote Share this post Link to post Share on other sites
palmero 0 Posted November 2, 2004 I have been trying to get 1 in fact at 1 point they emailed me saying it was sent but it has been 3weeks and nothing has been recieved...I called them back and they refuse to take my addres sinfo over ph to verify that the address I emailed to them was correct saying they would only take my address via email. I emailed my address for the 3/4th time and still no response has been recieved from them saying whether or not it has been sent. I have been going thru this proces for about 5weeks now. I am in Arizona they are in California so it should not take that long to recieve. Quote Share this post Link to post Share on other sites
notoriousbigs 0 Posted November 2, 2004 i will check with benson today about your request. Quote Share this post Link to post Share on other sites
palmero 0 Posted November 2, 2004 great, thank you I have emailed you some info thta may help you locate me in the system. Quote Share this post Link to post Share on other sites
notoriousbigs 0 Posted November 2, 2004 I just checked with Benson and he packed it up and gave it to the shipping department already. THey're sending it out today. Quote Share this post Link to post Share on other sites
palmero 0 Posted November 2, 2004 thank you soo much for your help and hope this solves my problem. Quote Share this post Link to post Share on other sites
