Serus
V8 CPU Cooler - What cases DOES it fit in?
Overproof    0
I can tell you it will NOT fit a CM Stacker 380 SE..... with the inner door fans mounted... which is totally ridiculous as far as I'm concerned.
cmyers    0
Just take out the top corner fan. Or the whole fan bracket. You really don't need that many fans.
slugbug    0
I think you mean 830 SE :)
Overproof    0
I've removed the fan..... it's the fan bracket that won't fit. So I either have to undertake some creative dremel work or nix the entire fan enclosure. Despite what you "assume" is too many fans or not.... I bought the case with the fan bracket for a reason. That reason didn't involve water cooling and it would seem logical that Cooler Master could have provided some information to clarify that one of their largest cases wouldn't fit a V8 without alteration of the case components. What really sucks backwash... is to find out midstream of a new build!!!
..and another thing since I'm on a rant... why can't these companies make a case with cable races built in???? Sheesh Already!!!
Overproof    0
Yup... 830 SE :D
Other than the fit issue with the V8 and lack of cable races.... it's a sweet case for air cooling.
