bsodftw
COSMOS S PROBLEMS NEED HELP PLEASE!!
bsodftw    0
Hey guys. im using a 750i ftw mobo with my cosmos s. i can't get the system to turn on. im not sure if i have my hdd led and power sw header properly in. my mobo has the blue and orange light indicating that it has power. but the system wont turn on when i touch the activated sensor.
and the case has a RED SATA CABLE. where does that go? do i plug that into the mobo or my hard drive? since im using an Nvidia board. does my ram go into DIMM 2 and 4, rather then 1 and 3?
pleasee help me!! thanks!!
dubzhouse    0
Did you plug the 24 pin power cable from your PSU into the 24 pin extension that came with the case? Once you do that make sure you have the black and purple wires clipped together (One from the case power button and the other from the 24 pin extension). The red sata cable is your esata cable. Are your hard drives sata? Also your memory goes into slots 1 and 3.
