manumans
RS 850 ESBA voltage problem
manumans    0
Hello guys,
i have voltage prblem with my PSU, it show me 10V instead of 12V
hope you can help me. thank you
config:
AMD phenom 9950 BE
ASUS M3A79-T deluxe
4GB Ram Corsair
EAH 4870X2
PSU RS-850-ESBA
Windows XP PRO
its not really best to rely on a software based program for PSU readings...to get a more accurate reading you should use a voltage meter. checking the voltage in the Bio is usually more accurate than software based....check it in the BIO. I would also suspect if your voltage were 10v you would be having all kinds of power issues with your computer. (CPU-Graphics)
here is a video that helps explain using a voltmeter for the most accurate test.
http://video.google.com/videoplay?docid ... 8042569466
Zenphic    0
At that voltage, your PC would be having lots of stability problems. If not, it comes to show how inaccurate those software are.
