Jonathan1980
CoolerMaster RealPower M520 red led lights up once?
Hello all,
A while ago I bought the M520 PSU. Everything works fine, but there is one thing I worrie about.
When I put the power cable in the PSU and turn on the computer the red led lights up once (1 second) :shock::?:
After this (I leave the power cable in the PSU offcourse) the red led stays off every boot.
It only happens at the first boot after reseating the power cable.
I don't do weird things with my computer. I only remove the power cable when I'm installing new hardware or removing all the dust inside the case.
Is this normal? A test or something, if the led still works? Or is there an other problem?
More people who have this short blink with their M520 PSU?
I searched the forum, only found this topic: viewtopic.php?f=14&t=9052&p=78227 ,
could not find an answer there...
Greetings,
Jonathan1980
I think the PSU is broken. The red led is blinking once at "every" boot now.
And I only added a new gfx card (MSI Radeon 3850 256MB) :?
I'm going to take it back to the shop.
Greetings,
Jonathan
cmyers    0
Well, according to that link you posted, this seems normal for that type of psu. As long as everything works fine, I don't think its anything to worry about...
