andygibson
Using Two Hydra Coolers
Kahnman    0
No I believe you must run the line out from the top card to the line in on the bottom card. The line in is the one farthest from the fan (towards the back of the case when installed). Just a thought for you, I have the same setup as you (2x 8800ultra's with hydra coolers) but I found the hydra coolers reduce the flow-rate in my loop, so I split my loop before entering the hydra's with a 1/2"id 'Y' adaptor and ran 2 lines to the 2 hydra's then rejoined the loops with another 'Y' and on to the rad. I find this makes more sense as it increases the flow (a little) and your not running heated water from the first card into the second card. Hope this helps.
