andygibson
Aquagate Max - HELP
andygibson    0
Great as I have read so many negative things regarding off the shelf kits.
I have two CM Hydra Air/Water blocks for the 8800GTX cards and a Swiftech Apoyee GTZ for the CPU.
So I guess I will be able to run one loop? Also If I added a second single rad, would the pump manage ok?
biggatomic    0
yes! yes it would!
donta1979    0
did not read your specs but a good review is on Guru3d on this kit, the weakest part is the block you can shave about 15c off the max load temp if you change it out with a quality cpu block, letting you do some enthusiast overclocking.
