theoks75
Coolermaster Real Power M700 boot failed
theoks75    0
My system was running fine for 6 months. Problem now is as follows:
- press power on button, all fans start running for 3-5 seconds, then
- whole system shuts down, then
- all fans starts running again, and stop at error code 88.
What I have tried:
- booting using 1 stick of ram only
- update BIOS to version dated 2008/10/2
- changed new graphics card
- flashed CMOS
all of the above doesn't work, untill..
- plug in generic PSU, everything works fine...!
However I tested the original coolermaster M700 on another system and it works fine too!
Is there any known compatibility issue between this mobo and this PSU???
Any way to resolve this?
Maxession    1
That's strange, it worked for 6 months, an still does but not with that computer anymore. :?
Have you done any hardware changes or bios updates before the problem?
knud    129
Although it works on a other system, it looks like the PSU is faulty.
I strongly suggest to RMA it, to prevent any further troubles you might have.
