VoongKoong
WaveMaster Top Fan
VoongKoong    0
Hi, I have a CoolerMaster WaveMaster case, and I want the top fan mount that comes with the case. I don't have it for some reason, and I was wondering where I could get one :? . My case temperature is not satisfactory(at least not to me) and I am willing to pay good money to anyone who's willing to sell one to me :wink: . Or is there any store I could get one from? Thank you :lol: .
ShaShou    0
Any old 80mm fan should be good enough, very easy to find at any computer store, and not expensive. Of course, you should get a Cooler Master one.
It is an easy do-it-yourself project, just need to remove the USB/1394/audio thing that's already there, screw the fan into the provided grill, and screw that into the top of the case. Connect the fan to a power supply, and you're ready to go.
One question maybe someone else can answer is should the fan blow into or out of the case.
Hope this helps.
Infinity    0
VoongKoong - try contacting bryant (bigbadbns), he might beable to send you one or tell you where to get one.
ShaShou - a fan in the top of a case should extract the air from the case because heat rises.
VoongKoong    0
Yeah, I'm talking about the fan mount that replaces the top USB, IEEE port :? . I contacted Benson, and hopefully he'll make one available :D . Or if anyone would like to sell it to me, I'm glad to accept the offer :) . And I apologize for posting this twice, but I'm desperate...I even dreamed about having one when I was sleeping(So geeky...)!
