aSASa
240mm+ fan bracket for Stacker 83X series
aSASa    0
I've wanted to put a large intake fan on my stacked for awhile now. If only there was a tray and fan to go there, hint hint?
IF this is considered, my only problem would be that the HDT-S1283 CPU heatsink I'm using leaves just a few mm between its heatpipes and the fan bracket. A possible fix would be the bracked hanging over the side a few mm + a thin fan.
If this gets made, I'll be the first to buy it. The 120mm's just miss my Striker II Formulas NB + SB, so they hit 90C+
Rudieman    2
The stacker is too old for the designers to even consider it. I think if you really want a big fan you have to mod something yourself. Maybe you can adjust the existing fan tray?
Rudieman    2
Yes me to. I think its still the best coolermaster case but unfortunately this case is not being sold a lot anymore. Most people want something new.
