InSaNe
Can't get lower rpm than 2500 with Jet 7+
InSaNe    0
Today I bought myself a Jet 7+.
First it wasn't a problem to run the blower on 1900 RPM, but now I can't get it lower than 2500 RPM. How is that possible? (running on an AMD 2400+)
The day before yesterday I also bought a new mainboard Asus K7N8X-X so I don't think that's the problem.
Mr. Miyagi    2
Do you still have the fan connector on? When you turn it does it change in speed? If you have the fan controller cut off, you can get a 4 to 3 pin adapter, plug it in to the mobo, then use the bios to change the voltages to get it to the speed you want it to run at.
4 pin to 3 pin adapter.
