aleicgrant
Cosmos S water cooling
aleicgrant    0
would someone who has watercooled their cosmos S be so kind to share pics.
I am trying to determine the best set up and the equipment to use.
Looking at putting three fans on top and the rad right below or I might do something external
thanks
biggatomic    0
Aquagate max with swiftech MCR320-QP Radiator
idle temps are in the mid 30's load mid 50's ( tri-sli heats up my case significantly )
biggatomic    0
ok so whats the consensus here.
Rad inside case with fans on top or the other way around?
MCR320-QP is the rad I am looking at
3 120mm fans
inside or have 6 fans top and bottom "push pull"
aleicgrant    0
there are the choices I have for a triple rad that works with the cosmos S (sadly the swiftech doesnt)
which one would you choose and why
HWLabs BlackIce GT Stealth III
HWLabs BlackIce GT Xtreme III
HWLabs BlackIce Pro III
HWLabs BlackIce GT
Watercool HTSF 360
XSPC RS360
XSPC R120-T
Aquacomputer Airplex Evo
Aquacomputer Airplex Pro
Alphacool NexXxoS Pro III
Magicool Aluminium 360
Magicool Xtreme 360 Radiator
Magicool Slim 360 Radiator
biggatomic    0
ok getting mixed comments
I drew this diagram
best way to go?
yes thats what i was talking about. as for the rad. i dont know.
