pwrmngr
COSMOS 1000 and Real Power Pro 750 not playing nice
pwrmngr    0
Ok after several months of putting off building the perfect beast i dived in and started.
Got the mobo and chip in but the power supply mentioned does not line up with the holes.
Any suggestions as to why? and any suggestions to what I should get?
Thanx :)
Coolermaster COSMOS 1000
Coolermaster Real Power Pro 750
Zenphic    0
That's okay. As long as you can screw in 4 screw holes, it's okay.
Either ways, the power supply is installed at the bottom, so securing it is easy.
RaptorFury    0
its supposed to be that way , mine was the same way as well , this allows cm to have the psu mounted 2 different ways . just put a screw in all the appropreiate holes on the psu and it will be put .
