smargi
Coolviva and 6800ultra
smargi    0
can this vga cooler coolviva fit a nvidia 6800ultra and what about the ram what can i use to cool them and if this is enough cooling for this card....?
gr2000    0
yes, Cool Viva is enough for cooling your 6800ultra, whether it fits or not, you might want to measure the thickness of your graphic card. go here http://www.coolermaster.com/index.php?L ... serial=109 to learn more about the dimensions and some very useful FAQs
as for RAMs, you can get RAM Sinks(Copper) : http://www.coolermaster.com/index.php?L ... Ram%20Sink
other chipset coolers can be found here : http://www.coolermaster.com/?LT=english ... _class=102
smargi    0
DID ANYONR REALY TRY PUTING THIS COOLER ON A 6800ULTRA I SEE THAT INNO3D HAVE A VERSION OF THIS COOLER WITH THERE 6800 CARD BUT ITS NOT THE ULTRA THE ULTRA VERSION IS ALOT HOT THEN THE 6800 NON ULTRA......?
Guest Mindless Moron
coolvivo isnt enuff for the ultra, its runs at 60idle its need water cooling or an artic cooler, passive cooling aint good for it.
im not sure, i wouldnt have touched the ultra with a stick
smargi    0
according to coolermaster tech support (email) this cooler does fit the ultra and it cool well waht do you think are they right or just try to sell this product....?
probabbly will do better than stock, but id just save up for water cooling, thosde gpu's run hotter than the 3.8 prescott cores from intel
smargi    0
i only want to change the stock cooler because on the realy loud noise is this cooler can keep the heat temp at the same level as the stock cooler do and reduce the noise level it's ggod enough for me..! the only thing that concern me that i didn't see anyone that realy try this product on a 6800ultra card and didn't see any review for it...!!
