ninuhadida
doing some testing on liquid cooling
ninuhadida    0
for the last 2 hours, i've been doing some testing, with an l20 hydor pump and waterchill wb (not antartica) to find out if using a big reservoir and no radiator would do as good as having a 120x120mm rad but with no reservoir. for the water temp i used a normal temp senser, putting it in water. (lol some serious testing :D ) The result was that having a big reservoir with no rad the temp of the cpu and the water temp increased a 1c every 12minutes with running toast at normal priority. this convinced me that if i have a 4 block system (cou, mb, gpu, hdd) with a hydor l35, big reservoir (holding about 2litres) and a 120x120mm rad would be enough. i have to use a 120x120mm rad cause i'll be putting the system in a wavemaster (planning to be similar to the case that liquid_cooled have).
sorry for my bad english :?
