jhage
Aero Blower AAB-V81
ninuhadida    0
sorry mindless moron, but all case fans (including cpu coolers) if you change the + with the - they won't work. they just won't turn. if jtag is meaning for the aeroblower (which comes as a case fan) it doesn't do any noises and it's low cfm (about 20cfm :? ) the aeroblower that comes as a cpu cooler it produces a lot of noise (i think about 35dba with only about 35cfm) not quite sure but, but it is really noisy
Guest Mindless Moron
I am already aware of these poitns and remember aero blower hasa low cfm but the air is at higher or is it lower pressure causing it to be colder.
VoongKoong    0
If you put the blower outside of your case on the top, it'll push hot air back to the center of the case, causing higher temperatures. Also, regular 80mm fans can push more air...
