VALKYRIE
CM690 with the Hard disk cage turned in a wrong way,
VALKYRIE    11
Hello , in my opinion the orientation of the hard disk drive cage of the CM690, can restrict the airflow into the case , look at this AirFlow Cases Laboratory Test , to check , how the orientation of the walls of the Hard disk cage parallel to the side panels of the case give the best airflow in the Cooler Master Stackler , Akasa Mirage and Antec P180 , in comparison with the other cases in which the hard drive rack is turned in a wrong way ,restricting the air flow from the front intake fan,
http://www.antec.com/pdf/customPC_p180test.pdf
This is part of a review about the CM690 ,I got in magazine CUSTOMPC ( issue 052/january 2008 ) here in London ............."However ,while the hard disk have a dedicated 120mm fan, little air flow will access the main chamber ,as the hard disk cage is mounted perpendicularly to the case " ...........................
VALKYRIE    11
QUOTE FROM............ "iron_gr"
Bought this case. It's nice, a little more noisy, I expected it more silent.
It has a production error! The ground cable of the IEEE 1394 above the I/O panel is not grounded! It is with the screw that holds the i/o panel in place. I took it from there and grounded myself straight on case.
If you can pass it to the guys that put it together, would be nice.
Back to top
VALKYRIE    11
:D Hi ,I got this in a australian website....... hppt://forums.whirlpool.net.au ...... ,the owner of this CM690 rotated 90 degrees the Hard drive Rack to face front to back instead to leftside-rightside to improve AirFlow inside the case ,this are his words :
Yes this a nice case for the money
Bought one yesterday without power supply
Had to modify the hard drive bay to increase airflow (rotated 90deg)
Very quiet running 7x120 fans (inc. cpu)
img255.imageshack.us/img...cm690gutsge9.jpg
Rudieman    2
I think he meant also the airflow into the rest of the cage and not only the HDD's. But that was almost a year ago!
Create an account
Register a new account
Sign in
Sign In Now
