eternity
Will it fit?
eternity    0
Hello all. Been a while since I posted here. Hope someone may be able to help me out.
I've got a Coolermaster ATCS-201B-BTX (Black Widow) case. Does anyone know if this case will accommodate a 8800GTX graphics card? Or better yet, if anyone has one fitted in this case, or a similar model.
Cheers for any help.
Maxession    1
Don't know if it would fit, but the modelnumber is: ATC-201B-BXT I assume...
You could try to see for yourself with the method used here and see if it fits...
Fireheart    0
I'm not certain, but I believe Anarchy[HWLUXX] may have the most experience with ATC cases on the forums. Perhaps you can PM them?
Be Well!
Fireheart
knud    129
Same goes for harib0, she has a lot of ATCs chassis her self.
She is also in the forum.
lozza    1
Hi eternity,
Going on the fact that the 8800GTX is approx 28cm long in Theory it should fit, maybe slightly tight you will have approx 10mm space between the card and the drive cages.
However i don't have one of these cards so can't be 100% certain. I may know someone who is using a 8800GTX or similar, so will try to contact them for you and see what they say.
eternity    0
Thanks Harib0!
Just can't bring myself to divorce this loverly case. I'll wait till I hear back from you till I make the purchase.
Cheers.
lozza    1
I was correct in thinking the fella i knew had one and so we have confirmation:
I was using a BFG 8800GTX if I remember correctly. Either that or a GTS (I can't remember 100%). It fitted though and had plenty of room - in which case I guess the 8800GTX would be a definite fit, if I used the 8800GTS ...
Glad to be able to keep a ATCS in use!
