coemery
12V rail problem
coemery    0
Hi,
I have two CM PSU that I have recently tried with a new system I am building. Both PSUs seem to be giving less than 8V on the 12V rail according to speedfan.
Did I really get 2/2 defective PSUs? Is there some way the motherboard can be affecting this? I have the latest edition of speedfan.
Here are the system specs:
E6750
Abit IP35-E
GeFroce 6200
320GB SATA HDD
DL DVD Burner
PSUs:
RP-550-PCAR (showing 7.3V)
RP-500-PCAR (showing 7.7V)
I have serious system instability and can not make it for 30 minutes in orthos at stock settings.
edit: In the BIOS it is showing as 11.89 which should be enough....my speedfan is faulty somehow?
EsaT    0
If 12V would be that it would be miracle to get PC booted.
I would start troubleshooting from BIOS side. (like memory voltage)
