cuooler
eXtreme Power PSU - anyone have one that is NOT Noisy?
cuooler    0
Hi there,
Based on the Cooler Master name and some reviews, I forked out for an eXtreme Power 600W to replace a blown PSU. Unfortunately, like many others (links below), the fan runs at top speed constantly. I use water cooling and so it's really obvious it's the noise source. I've tested the system with bare components (eg only the motherboard + gfx card powered) and there is no way the RPM of the fun changes at all.
In most of the posts below, people seem to suggest it's a faulty unit, or that the PSU should be exchanged for another model (dodging the issue methinks).
So I'm curious: Does anyone (non-coolermaster employee) have an eXtreme Power series PSU that actually does change it's fan speed based on load, or is this "intelligent fan speed" feature just a bogus sales pitch?
http://forum.coolermaster.com/viewtopic.php?t=7529
http://forum.coolermaster.com/viewtopic.php?t=7232
http://forum.coolermaster.com/viewtopic.php?t=7013
http://forum.coolermaster.com/viewtopic.php?t=6873
http://forum.coolermaster.com/viewtopic.php?t=5977
http://forum.coolermaster.com/viewtopic.php?t=5476
ps: I really can't be bothered with a painful RMA process so I'll probably end up stripping the thing down and mod it to work with an external fan controller. if / when i get to this point, I'll post some JPG.
SINneR    0
Ultra X3 1000w sounds quiet enough to me... :)
unless your talkin' over 1200w... :? ... but, I never used over 1000w... :shock:
tkl.hui    0
before i oced my cpu, it used to run pretty quite and would go up on load, but when im on load or have my cpu oced, the fan makes an irritating clicking sort of noise as if its hitting the fan grill. really annoying =/ the place i bought it at wont let me get a new one eithere :|
SINneR    0
:arrow: :arrow: :arrow: :arrow: :arrow: :arrow: :arrow: :arrow: :arrow:
Sucks when parts make loud noises!! :x
I have gone through so many PCs, and time over time had to fix parts myself... :(
Many, many fans, & not to mention re-soldering back on SMT components the size of dust! :shock:
If you need ( tkl.hui ), I will fix the PSU for you for a very small fee (paypal or money order).
I have my own little PC shop and I have a +record on ebay: "rjf-pc". :)
http://hub.ebay.com/community?_trksid=m37
If not then, buy an Ultra X3 1kW, it's very quiet, affordable, and should do you good. :D
I use an X3 with:
+ EVGA NF68-A1 OC'd FSB
+ QX6850 @3.7
+ 2GB Dominator OC'd
+ 2 8800ULTRAs w/ GPU OC'd, MEM OC'd
+ X-Fi Audio
+ 10,000 RPM 150GB WD Raptor
+ 7,200 RPM 500GB WD Caviar
+ 7,200 RPM 320GB WD Caviar
+ 6 High speed 120mm Case Fans
+ 18w Liquid pump
+ 16 High power LEDs.
I got this Eye-Candy RIG to push out 19,640 :shock: in 3DMark06. :D
http://service.futuremark.com/compare?3dm06=3646493
... contact me: ( contact@rjflash.com ) if you wanna see pics of the RIG... :)
8) -RJF-PC
Maxession    1
The place you bought it, is obligated to respect the warranty conditions, they have to give you a replacement or RMA themself if it is within 1 year. After that you should RMA it yourself.
Also, if you let somebody outside of CM fix it, the warranty will be void.
(PS; check if the fan grill is isn't in reverse...)
tkl.hui    0
thanks for the advice, i reversed the fan grill and the noise went away for an hour, then it came back, but not as loud as before. I was wondering if it is possible to not use the fan grill? if not, im considering getting a new CM rc690 so i can place the psu at the bottom upside down so that the noise doesnt occur.
vidra    0
I have a 550W eXtreme Power PSU and I was constantly experiencing jet-takeoff noise (OK, I know I'm exaggerating but you could hear it clearly 2 rooms away). Today I finally had enough and I decided to take it apart.
To my surprise, the PSU contains a standard 120mm fan which runs at high RPM, which is the source of the near-intolerable noise. I decided to take the chance and replace it with a Cooler Master 120mm silent fan and it worked like a charm.
My only worry is that the new fan won't cool enough and that the PSU will start overheating. To test if everything was going fine I ran Hellgate London for an hour (I have an OCed C2D and a X1950pro) to maximise power consumption and the air that was coming out of the PSU was barely lukewarm and the PSU was only slightly above room temp to the touch.
I only hope it will stay that way as this seems a cheap and permanent solution (it voids the warranty, though).
