Daedra
CM-690 - 2 pin to 3 pin Power LED Adapter?
Daedra    0
Hello I recently purchased the CM-690 and the install went well except that my Asus motherboard wants a 3-pin power LED while the LED plug that came with the case is only a 2 pin. If you look on the newegg reviews this is a common complaint. Does anybody know where I can get an adapter because I really don't want to cut or rewire the switch.
Thank You
knud    129
We don't have adapters for it.
The only solution is to cut the connector in half.
afunguy26    0
having same prob as Daedra now I got to cut my cable in half?
this will void my warranty so i'm screwed
this is whack now I got to mod a brand new Case :x
btw I didnt find anyone complaning about this at newegg except Dadrea :S
I did find some reviews who said you need a two pin mobo to make it fit.
afunguy26    0
I know a guy plugged it to his suspend led light :o Im using a abit ip35-E mobo I dont wanna use any adapters that you are using on a asus mobo. Im going to try and plug it into suspend led pin I'll tell ya how it goes. :D
Daedra    0
directron has been sold out of that adapter forever. That is why I had to make my own. Afunguy the adapter really is not an "adapter" in a traditional sense, that plug is just a + and - and the Asus motherboard is + - that is why just cutting it in half works I just like you did not want to do that. Let us know how it goes.
