Paul343
CM 690
knud    129
I hope this front view is good enough for you :)
and a picture of the I/O panel, it's the only one I have
-=Draven=-    0
Thanks for the pictures :D
Will the CM 690 be part of a series of cases, like the Elite case?
i.e. Several models of the case with the same interior but with a different look?
cozzyb    0
hi, very good fan of coolermaster and currently using a cavlier 3 :P, wanting to buy this new case when its out, was just wondering a few things.
Do any of the fans holes have dust filters on them?
How many fans and where are standard (included)?
Is the release date mentioned above the same for europe? and will it be likely to see in etailers around this time?
Can you give a rough price in pounds or euros w/e is doable on the case (as it is never straight dollars to w/e)
Can you confirm the fan behind motherboard will only fit a 8cm fan with 15mm thickness and not the more common 25mm?
Thanks very much.
knud    129
The bottom, front have filters.
There are 3 fans included.
Release date for europe I need to look up. I'll get back to that.
Price will be around €79.
And the fan behind the mobo should be this size:
80*80*15
-=Draven=-    0
Can a CM Tech Support answer this? Please.
Thanks :wink:
-=Draven=-    0
About the I/O Panel, as shown in the pictures, it is located on the top of the case, but I saw on different websites and also on CM's North American website that the I/O panel can also be located on the front of the case (optionally).
Is that true?
-=Draven=-    0
No, it can only be placed in the top.
I just checked the product's manual, on CM's website and the specs says that :
Model RC-690-KKN1-GP: It's I/O panel is on top.
Model RC-690-KKN2-GP: It's I/O panel is on front.
So that would mean that there's two models for the CM690.
knud    129
You're right, there are 2 versions, but RC-690-KKN2-GP is for the Japanese market.
