Iverieli
Help! I need to find a mobo that will fit GeminII!
Eliminator    0
I own the Asus M2N32 SLI DeLuxe and the only way to mount the GeminII is verticaly. I you want to use it with two 120mm fans, then forget SLI, as far as the first PCI-e will be under the fan. The only way to do SLI with the GeminII is to set it as passive
