Guest Mindless Moron
ATCS 200 window HELP!!!
right i have a problem trying to get a window for my atcs 200, now i have found 2 on offer, for atcs 200 version 1 and version 2, i bought the version 1, i found it did not fit my case and connected to the case differently, i dont know about the second, for referance, the atcs 200 uses the exact same type of side pannel as a praetorian, except the colour is more of a dark grey.
This is the version 2 pannel
http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=49999
is this the one i want?
any chance if a CM person reads this u oculd respond
Mindless,
I will check for you when i get back to work on Monday. I remember it has to be a cx1 version for it to work with the side panel but i will get a confirmation on it.
