N3RO 0 Posted February 24, 2007 Hardware to be used: Final aspect: I received this today: White LEDs under of the board: LEDs of the bottom: Wash the RAD: []s Quote Share this post Link to post Share on other sites
N3RO 0 Posted February 25, 2007 Little progress... Cut for rad: With the ACRyan Radgrillz and a fan to test: Perfect? Testing the alignment: Just Perfect! Cut of a metal support: Little test between Radgrillz + Fan + Rad... All ok []s Quote Share this post Link to post Share on other sites
notoriousbigs 0 Posted February 25, 2007 can't wait to see the final result. Quote Share this post Link to post Share on other sites
N3RO 0 Posted February 25, 2007 can't wait to see the final result. Thanks m8 Quote Share this post Link to post Share on other sites
N3RO 0 Posted February 27, 2007 Side Panel almost ready... []s Quote Share this post Link to post Share on other sites
nuke072786 0 Posted February 28, 2007 Wow, looking REALLY good, what are those things called holding the LED's in the case? And I'm assuming they are being wired in parallel with one another? Quote Share this post Link to post Share on other sites
hed420 0 Posted February 28, 2007 I believe they are called led holders. How did you cut the fan grill? Looks really nice and clean. Looks as though you used a laser cutter. Quote Share this post Link to post Share on other sites
N3RO 0 Posted February 28, 2007 Yes, laser cutter. Led holders Quote Share this post Link to post Share on other sites
hed420 0 Posted March 1, 2007 Yes, laser cutter.Led holders Do you own a laser cutter or you had it cut somewhere? Quote Share this post Link to post Share on other sites
hed420 0 Posted March 1, 2007 Yes, laser cutter.Led holders Do you own a laser cutter or you had it cut somewhere? If so, how much did it cost? Quote Share this post Link to post Share on other sites
