wayne
question on temps
wayne    0
I have a CoolerMaster Praetorian case with a Pentium 4 2.80
processor with OCZ Premier 1GB ram. My motherboard is an ASUS P4P800 Deluxe. CPU fan is the packaged fan that was supplied by Intel (retail pkge.) I
'm using ASUS Probe softwate to check my temps.
CPU temp averages 44-52 and motherboard temps average 33-36.
Is this a standard temp range for this type of setup or a little high???
Wayne,
Your CPU temp is a little high for a P4 2.8. Is it a Prescott or Northwood? The CPU temp you're getting is it idle mod or running intensive gaming?
Mr. Miyagi    2
You should run Prime95 and see what the avg. temps. are. It's a great stress program and will test to see if your computer's stable.
Guest Mindless Moron
intel stock cooling is :), that sounds about right, 52 at full load my prescott has massive ammounts of cooling on it
