bry1987
door hinges
bry1987    0
i just bought the black stacker 830 and upon trying to switch the way the front door opens, the plastic hinges snapped...both of them. is there anyway i can just buy the two hinges instead of replacing the door? oh and this is revision 2 stacker 830 ;)
asgneto    0
Try to contact the costumers support for US of CoolerMaster...
customersupport@coolermaster.com
They can supply the replacement hinges for you.
Here in Brazil, the customer support has taken care of to all the problems with extremely fast.
bry1987    0
i emailed the address you gave me a few days ago, but no response yet. how long does it usually take for them to respond?
asgneto    0
Here in Brazil, the customer support delays up to 48 hours to give us a reply/solution for our questions/problems.
Try a direct contact with KitKatBar (Admin/Marketing Support)...
http://www.coolermaster.com/phpBB2/prof ... file&u=225
Or, sorjorla (CMUSA MKT Support)...
http://www.coolermaster.com/phpBB2/prof ... ile&u=5209
Send a PM to them... They probably will help you.
Create an account
Register a new account
Sign in
Sign In Now
