elny123
need help with compatibility between RS-450-ACLY & asus
elny123    0
I've used the RS-450-ACLY in this set up for a good year:
RS-450-ACLY
Soltek SL-K890 Pro
Corsair XMS 2x512mb pc 3200 400 mhz
Raidmax case (forgot what it was)
AMD 64 3000+ S939
BFG 6600 GT PCI-E
Creative Xi-Fi extreme music
I decided to change some of the parts to this:
RS-450-ACLY
Asus A8N-SLI Premium
Antec P180B
AMD 64 3800X2
XFX 7600 GT KO
With the new setup, I can't power down using the button on the case. I have to flip the switch on the power supply. Also, when I first got the mobo, I was able to do a fresh install & get to the desktop but still couldn't power down either through the button on the front or through windows.
After I RMA'ed it & received it last week, it would not display any input from the computer on my monitor. I still could not power down from the front.
I am wondering if the power supply is not compatible with the mobo or if it could be something else totally. I would hope that Asus did not send back the board to me without completely testing it only to have another problem crop up.
Can anyone chime in here on what is going on or what I need to do?
Thanks,
Ethan
knud    128
The psu is compatible with your asus mobo. That shouldn't be the problem
zerospace    0
Agreed. I think you need to take this up with Asus a bit further. ;)
If you cannot turn the power on from the front of your case, you also might see about checking that switch on your case.
elny123    0
i can turn the computer on. it just wont shut down properly. i cant power down through the button on the front & through windows. i have to flip the power switch on the power supply.
in any case, mobo is going back again.
thanks all!!!
zerospace    0
thanks all!!!
Sounds like a decent place to start, at least. Good luck!
