djnsmith
Removing Front Fan on Black Stacker 830
djnsmith    0
Hey Folks,
First time CM owner here of a Black Stacker 830. Just picked it up today.
I have since figured out that these pushpins can be removed in order to remove & replace the fan. I've never worked with these pushpins before & can't figure out how to remove them. Can someone please explain how to remove them.
Thanks!
Insert your nail on the side of the pushpins... You will see that your nail will insert in a little space... Not the space between the pushpin and the cage, is on the pushpin's head. Then lift the hand and the pushpin is open... Remove it, do the changes you need to do and remount again.
djnsmith    0
Thank you. I just grabbed a butter knife & pushed the middle piece through on the bottom of the pushpin. I didn't realize that's how these worked.
