Phuncz
Aquagate with two radiators
Phuncz    0
I'd like to know if the Aquagate's pump is strong enough to survive two 120x240mm radiators added to the mix, as I want it to cool my CPU, northbridge and videocard. And the freak that I am, I always got to have overkill written all over :D What I need to know is that the pump won't die because it can't handle the power required to push the water around.
knud    128
:shock:
That must give you a lot of cooling power (not just a cool cpu, but to keep a OC'd cpu cool)
Phuncz    0
Yeah that's the idea :D That the system is prepared for anything coming at it in 3 years or so :) Including hot summers :D
knud    128
To be honest, I don't think the pump is able to let it work 100%
(you know Ron, right? Ask him :) )
Phuncz    0
Yeah but he is on vacation :) Well, I'll just buy two Aquagates and have each one handle an extra 240x120mm rad, that shouldn't give too many problems I think...
RaptorFury    0
1 guy did use a second rad but it was a 120 x 120 on a augagate . the only way i can think of it pushing thru them rads is by eliminating the rad inside the unit itself ... and open the barbs from 1/4,or 3/8 inch to 1/2 inch barbs ...
