The_Big_Fish
will thay work with my old cpu
i am stuck with an old AMD Athlon XP 3200+ (Socket A) and i was wondering if the AQUAGATE(RL-HUC-E8U1/U2) or AQUAGATE Mini R80 / R120(RL-MUA-E8U1 / EBU1) world work with my cpu
(i ask as some sites say thay it would work but on the coolmaster site there is no info on athlon socket a)
thx
kbates666    0
Yes the blocks on the aquagate will work on a Athlon XP 3200.
O, you may not think so but the 3200 is still a good processor I wish I had one.
its only 2.2 GHz but then i know people who have had them overclocked to 3GHz so i suopse thay are not bad, i just wish i had one of the new 64 bit ones.
edit:
also what aquagate should i get (the small one costs more but the bigger one looks like its better? (going by the prices in the shops in the uk)
thanks
knud    129
The aquagate mini 120mm has more coolcapicity (better for OC), but don't know if you can reach the 3 Ghz.
And it's a nice cpu 8)
and check this out.
It provides the answer to your original question :)
