coolermasher
Max temps for AQUAGATE tank????
hi there peeps..
ive recently installed a aquagate system(not the mini 1) and as ive read in these forums how to release all the air bubbles etc and all is fine now..
my max tank temp (idle temps)is 38.2 on fan speed 1 and 34.4 on fan speed 3...
id like to know the max temp that the tank will go to as i have another coolmaster fan but only spins at half the speed(and near silent) of the original 1 provided within the aquagate
original coolermaster rifle fan @ 3330 rpm@34.4 degrees @speed 3
my coolermaster uv fan @ 2400 rpm@40.6 degrees @ speed 3
would it be ok to use the uv fan and have 41 tank temp constanly?
many thanks
kbates666    0
I switched my fan out for a blue led fan and have lost little performence.
Original fan was almost always set on 1, to keep same temp new fan must be set on 2 but it is way quieter.
Tank temp is only a reference. Does it really matter if your cpu temp is where it should be. What CPU do you have because those temps sound a little hot to me?
P.S. Changing the fans will void your warrenty
thx for the reply.....i have a (775)(2.66)prescot!!! damn things run hot as :)... and i think thats where they are made too? hehe also yesterday when i posted that thread my room temp was 31 degrees :shock:
with aquagate
my cpu temp idle is 41-45 and then underload it goes to 51-54
on my old CM air cooler
my cpu temp idle was 49-53 and underload was 59-63 :shock:
so for the £50 aquagate i lose about 10 degrees and i got some sexeh blue pipe watercooling and my shizzle is ALOT less noisy :) all in all im happy with it but damn that front rifle fan is noisy! :roll:
