PSymonhilly
cooler master sensor in wrong place? help plz
knud    129
Can you run a prime95 test? That's the best way to measure how hot the cpu gets and (hopefully) run stable
RaptorFury    0
or if you dont want to run it ucan do super pi @ 32million ( takes bout 30 or so min ) that will alos heat things up a bit , plus if it cant complete it theres issues ..
PSymonhilly    0
ok had no troubles for ages since that post but now the bloody thing overheats when i turn the pc on :evil::evil::evil::?:shock:
all this top notch stuff and its about as good as microsoft :(
how is this happening when the pc's not turned on
THIS SUCKS
knud    129
What is the ambient temp of the room?
That can have some influence...
Doesn't the pc start up at all, or is it something else?
What is cpu and tank temp?
stylish83    0
double check if the thermal sensor has not moved. If it hasn't moved then top up the tank of coolant. if it is still overheating then try moving the thermal sensor to another location. IF IF that doesnt help, them still a big room cooling fan in forn t of the aquagate. That will definately work...(last resort)
PSymonhilly    0
ok the pc has been off for a few days, but when ever i turn on the pc it starts beeping straight away.
how can something be hot if it not been on ???!?! :x
i think the liquid needs a top up coz thats the only thing i can think of....
we've had warm weather but isnt this the point of liquid cooling to get things cooler
i have 4x 80cm fans and 4x 120cm fans installed now and that solved the problem very nice but now this :?::?
does the next new aquagate come with its own repair/service man??
:shock:
al this new stuff and its worse than my older pc
PSymonhilly    0
and i still getting the same temps as when it runs nice :D but for some reason it bleeps when its no where near it shutdown temp??
it displays the same temps as when it ran ok
yup id try the topping up the liquid....but the water text box should be flashing on ur aquagate display if it is ya liquid at a low level...hope this helps coz i had same problem...and as soon as i topped up it stopped flashing and beeping :)
PSymonhilly    0
ah ok i found the water flashing ( didnt know that :(
it seems the problem has been solved thx guys again for ur help you are top guys :D
hope to see you soon but with no pc troubles hehe :lol:
THX
knud    129
Stick around, it's nice here :D
But good that you're problem is solved!
